Sorry if this has been posted before, I just found these online. Look like a decent option to fog lights. I always seem to get caught in thick fog or blowing snow while out hunting and the factory bulb are junk as we all know. Has anyone gave these a try?
http://www.visionxusa.com/OE_Mounting_Solutions-OE_Brackets/c142_132/p835/07-11_CHEVROLET_SILVERADO_FOG_LIGHT_UPGRADE_KIT_WITH_FOUR_2%22_LED_LIGHTS/product_info.html
Is like to see the final fit and finish on these I'd hate to butcher the plastic to make them fit. Look bright though.
Sent from my Nokia 5190 using Tapatalk 2
They look good, however I doubt they'd be much use as a foglight. Generally with fogs you want a particular pattern, and most LEDs are just designed to be bright, which is good for driving lights.
Another question for those of you running hid fogs, what wattage of ballast are you running ? I've seen 25 watt ballasts there more money but claim to not harm the housings. I've herd 35 watt are fine and won't melt but I've also herd they will melt the housings.
I'm also running 35w 3000k HIDs in my fogs with no problem. They aren't much help in the fog though. The housing just isn't made to handle that much light, it spreads the light around everywhere pretty much.
True 35w HID kits would be fine for the 5202 fog lights as they would run the same temp if not a hair cooler than the 27w 5202 bulbs from the factory. DO NOT run a 55w kit though, as you will certainly have issues!
http://www.visionxus...oduct_info.html
I can tell you (from personal experience working with LEDs for years) that applying the right lens to an LED bulb will give you an awesome beam pattern and LED bulbs are very controllable for cutoff and distance. Those lights in that link look like they would give you a great spread and beam.
Just an FYI, we are manufacturing some LED housings with 12 LEDS (36w total) which have a tight circular pattern. Amazing for offroad and auxiliary lighting!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
