Weird warnings when cold
It's been cold here (-2 this morning) and I had something strange happen twice today. When I started my 2011 Silverado and drove for about 5 minutes, the ABS light came on and I got the warnings to "Service Stabilitrak" and "Service Trailer braking system". I pulled over, turned the truck off and started again and the warnings went away.. Any ideas what would cause this?
Mine did this last winter. It ended up being a bad battery. Did several load tests and it showed fine. But it would also crank slow if it sat a few days. Stop in at an Auto Zone or somewhere and do a load test. Or just take it in, its under warranty.
I had the exact same problem on my 2009 Silverado and my stabliltrak system would stay on also causing "reduced engine speed" warning and reduced speed where I could only go about 20-30MPH. Also, the check engine light would come on in conjunction. It started when the weather got cold and temperature outside was below 30 degrees. It to would reset if I would shut off the engine, except the check engine light would stay on for a while longer. The dealers are aware of the problem. It is a bad sensor or relay that needs replaced. There is a service bulletin out on it in lieu of a full fledged recall. Guess they only want to replace the ones that go bad instead of all of them. The bulletin even covers the repair in full if you are past the 3/36 warranty. The free replae ment is because of so many complaints and bad sensors out there. Hope this helps.
What micromark is taking about is the TPS sensor coverage, there is extra coverage for that item.
In regards to the low engine power message, its time to replace the throttle body sensor (i.e. replace the whole throttle body assembly $150). It goes into this state if the stepper motor is off by a **** hair as read by the throttle position sensor. It prevents the classic runaway throttle as found in the early drive-by-wire F-150's.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 788 Guests (See full list)
