Doing some shopping, need some input
Tyler T
My EDC is a Glock as well. Sitting on the desk next to me right now. G32 in my case. Had it since spring of 2009. Been absolutely reliable, never a jam or misfeed or anything else. The finish is starting to show some holster wear but that just gives it character. :lol: The treatment Glock uses is actually under the black finish, essentially baked into the slide so even if all the black coating wore off it'd still be fine.
Yep, the finish is more of a steel treatment than a coating. You can sand blast it and the finish is still there.
I am a huge glock supporter, however my glock 23 is an early gen 4 and I've about 6 jams in ~6,000 rounds. To me that is unacceptable. They were all failures to extract. It also throws cases like crazy. Usually straight back into your face.. I've had all the replacement parts put in. New RSA, ejector, extractor. I had 2 failures in a class I went to shortly after I put the new parts in. Then I bought a Glock 19 and haven't had a single problem. Only jams were from some girl limp wristing it repeatedly. I've heard a lot of similar complaints about the gen4 G23s.
My Glock is the only one of my "old" guns that has never had an issue. Though the problems I had in the past on my Sigs and Beretta were ammo problems- stovepipes from weak rounds each time- you get that one soft recoil that makes the .45 feel like a .22 and you know something was wrong. :lol: When I use the Storm Lake 9mm barrel the ejection is a bit off sometimes, but never a misfeed. But I expect that since the extractor/ejector isn't tuned for 9mm and it may even just be because I always shoot indoors and some rounds that did eject fine just bounce off something and end up hitting me. It's hard to tell. I fully expect my HK and new Sig will be flawless too.
Made a decision today. Went with a S&W M&P 15-22. My local guy ordered 4 of them, they sent him 3 regular 15-22's, and one that was outfitted with a MagPul stock, forearm, and sights. I think it'll be something fun to take out and play with, and still relatively cheap.
Haven't had a single jam in my Gen4 G22 with about 4000 rounds through it.
Get a slidefire stock for it :)
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,157 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
