leaf springs
Adding Leafs might look good on paper but all your going to do is make your truck ride ruff as all get out. And if you put the extra leafs in then load it down till they start to sag your pressing your luck. Somethings going to break, like frame or driveshaft. I it were me I'd get the correct size truck or cut the trees into smaller pieces. Liston to CKNSLS he sounds wise.
Thanks for your input, But im fine!
I didnt add a bunch of leafs to be able to over load my truck.. I plan to load it the same just not have it sag or stress with the weight. And being that there oem leafs and not an arched 'add a leaf' the ride has not changed.
It will change the ride some, but on our truck it made the tracking and what not better at speed. And being a Dodge, it needs all the help it can get to go in a straight line.
I honestly havent felt a difference in ride.. But all my intention was is to add a little strength to the rear when its loaded.. which i did. I may still get the airbag set up and/or timbrens all depends if i end up pulling a 5th wheel camper or not.
    Clark_Elite
    Clark_Elite
  • Who's Online   4 Members, 0 Anonymous, 347 Guests (See full list)
