Chev 10 bolt to Dana 60
Well. last night my son finally did it, he blew the spider gears out of his 10 bolt playing in the snow.  I have found front and rear diff's out of a 1980 3/4 ton Dodge Powerwagon, how hard would it be to put them in a 1987 1/2 ton Chevy that presently has GM 10 bolts.  I know Chevy's but I know nothing about Dodge.  Is a Dana 60 a Dana 60, I know Chevrolet used to use the Dana 60 years ago in the 1ton and 3/4 ton trucks. How much is a Dana 60 worth.  Any help would be greatly appreciated before I jump in!!! Thanks in advance.
Awdvkd,
I am in the same boat as you.  I just scored a Dana 60 front axle and NV4500 5speed from a totaled 1990 Dodge 2500 Cummins to swap into my 78 K10.  I already know the particulars to swap the Dodge version of the trans but I am not sure how the axle swap will turn out.  I suspect the front axles on the older Dodge and GM trucks with leaf sprung SFA are direct bolt ins.  I remember in the 70’s when Dodge used the hubless fulltime 4wd many Dodge owners would add a Mile Marker part-time kit in the tcase and swap the entire axle to a GM Dana axle to have a rig with lockout hubs and part time 4wd tcase.  With that said I suspect the leaf spring perches are in the correct location.  Brake lines and steering should be straightforward.
You may want to visit the discussion forums at ColoradoK5 as those guys are hardcore wheelers and junk yard pirates.  Bet they will have an answer for us both.
i believe the spring plates on the dodge dana 60 are a little mores spread apart,  but using a hi lift to spread the jack would solve that problem eaily.
Thanks for the information, Something good happened for a change. A neighbor came by and heard of the situation and offered a truck he had sitting behind his barn and said we could have it for free.  Went and looked at it, its a 77-78 3/4 ton chevy w/ 14 bolt 4.10 8 lug FF, the front looks to be Dana 44 8 bolt. Not bad for free!! From what I see everything but the e brake will be a match. Now I have to find some 8 bolt 15 in rims, from what I have read they are available or use adapters.  I have a brand new set of 35's on 15's.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
