ls swap???
Considering and LS3 swap in 09 silvy, pros, cons?
The reluctor wheel on the crank is different than the trucks I believe. Might consider an L9H swap
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
If i do it, i'm goin to swap the transmission and put a 6-speed manual in, and pull out the center console and mount it there. A lot of custom work i know, but it'll be worth it i hope
Some of the Silverado ss guys have done the 6 speed swap and ended up going back to auto. The reluctor wheel has to do with the computer
But wouldn't the computer completely change with the new motor? I'm fully hearing what you have to say, i'm just full of questions
No. Just like with my swap it gets reflashed. I was told to stay away from the car engines. If you're going to swap and not race it go with the L92/L9H 6.2's from the denali's. They are cheaper as well. There is just a 20 HP difference which with tuning can be made up for.
I'm wanting a lot more power, i was looking at a complete motor swap computer and everything
Have you looked into Texas Speed for their complete engines? Have some built engines you can customize to your liking.
You're going to get more torque from the L9H than you would with the LS3
I'm on texas speed now, long block or short block? And what's the difference exactly?
Short block is block, and rotating assy. Long block is a short block with heads, cam, and valvetrain
No danny you must have LQ9
so long block would be cheaper in the long run
How much $$$? Gonna be about 100k more miles. :lol:
And BMC I'd only go short block if you want to do a bunch of custom valve stuff lol
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,242 Guests (See full list)
