ls swap???
yeahhhh i'll let them do that! I'm new into the whole motor building stuff, learning as i go! I've got a long road ahead of me before this project will take place but it definitely will happen
What have you got in there now? I've never really looked into having a manual installed should be interesting because these models never had a manual offered
Sent from my Nokia 5190 using Tapatalk 2
It's got a stock 5.3l with auto 4 speed
I plan on doing all the work myself, between my dad and i once i get him on board we should be able to knock it out.. hopefully
The problem i have with an auto is sometimes it gets confused about what gear it wants to go into, but it's also a stock chevy auto right now.. nothing to write home about at all
These built autos don't get confused
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
also rear end gears, 4.10's or 3.73's?
If you have a 4 speed now go with a 4 speed. check out finish line transmissions. I will be going with their Level 5 4L65E
Put an 8.1 in it with some raylar internals.. you,ll be over 500 hp and have all the TQ you will ever need.
A real motor should have more TQ then HP, unless your looking for a high reving import.
I'm not wanting a diesel though
8.1 is gas.
i assumed it was diesel. How much do they run for
Well you will have to go to a 4L80E transmission at minimum. Probably need to change motor mounts and computer. It is a Big Block. You will not even remotely get good gas mileage, but it will be a torque monster. Probably as close as you can get to the torque of a diesel without stepping up to a diesel
    HWN808
    HWN808
  • Who's Online   6 Members, 0 Anonymous, 497 Guests (See full list)
