Engine Knock 2006 5.3
TireSmoker
Hi, this is not a post about the common tick/knock that these engines have. My engine just started knocking, and it doesn't go away when the engine warms up. I have some lifter ticking, like everybody else, and the noise sounds similar to what I hear on a lot of youTube videos of other Vortecs knocking/ticking when they get really bad.
In fact, I thought it might be stuck lifter, but the noise seems to be coming from down low, and up front. I tried to stethoscope this, but I really can't pinpoint it. Underneath, I don't particulary hear anything from the tranny, or the oilpan.
If I remove the belts, the knock remains.
Sounds like a bottom end problem? I have 99,976 miles on the engine right now, and I have done light plowing on my own driveway since the truck was new.
I will add, there was a mild ticking and this sounds like that noise just got worse - so I'm concerned that it sounds like it's coming from the block, not the heads.
How can I figure out whether it's top or bottom trouble?
Thanks,
Dave
Did the 2006's have the 5yr/100K powertrain warranty or did that start in 2007??
How many miles? How is the oil level, has this engine ever "used" oil??
If your close to an oil change, try using 2 cans of SeaFoam brand engine crankcase & fuel induction cleaner. Add one bottle to the oil, then drive for 100 miles, then change oil using a AC Delco oil filter. Take the 2nd can & let it get sucked into the PCV hose, into the running engine. Then go & SAFELY drive the truck HARD somewhere.
Report back to us after a couple hundred miles....
Did the 2006's have the 10yr/100K powertrain warranty or did that start in 2007??
Started in 2007, unless I got robbed when I bought mine.
I had 3/36 warranty. My truck doesn't use much oil, a quart every 5k miles. I change the oil more often than that.
I will have the codes read tonight. The light is on with a P4055, just haven't installed the solenoid yet so I wouldn't have noticed a new light.
This knock is too bad for me to drive the truck, so there's not gonna be any 200 miles of seafoam or anything. I'll drive it to the store to get the codes read and back home and then that's it. I also think it's knocking too badly for it be a knock sensor, but I'll see if there's a code - it could be. Ha, I hope it is!
No knock sensor codes, just an evap code.
I seafoamed my crankcase, drove enough miles to turn 100,000 which was only about 5. It seemed like the noise reduced somewhat. I changed the oil, which came out pretty clean, btw, and the noise does seem lower. Still definitely there and sounding like a problem but it doesn't make me immediately feel like I have to park it.
I guess I'll change the lifters. Hopefully that'll fix it, cause that's all I can afford right now.
Probably not a lifter issue. I picked up a stethoscope, which works great - 1000 times better than a hose or a screwdriver. Knocking like mad in the oilpan, nothing in the bellhousing, very little in either valve cover. I pulled plugs one at a time, no change.
So, now I'm wonder what my next step is gonna be. I don't see how this engine could shit the bed like this at 100k. I've taken good care of it.
good luck to you ,and please dont throw parts it ........if you can take it out and apart ,do it ,if not ...well you know what has to happen ,,,,garage time
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,211 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
