All you 3.08 guys
njrado4x4
Still running stock 265/65/18's. Thinking about going to 305/50/20's when the stockers finally need replacing. Dont want to go too tall.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 281 Guests (See full list)
