Women drivers
Wingnut
I have to share this one:
I'm out in front of my house today, and the neighbors wife pulls up, and backs her 00 Tahoe Z71 into their garage to unload some stuff.
No problem.
A few minutes later, she leaves again to go somewhere else. I look up just in time to see the drop light cord give out. Seems that the drop light had attached itself to the roof rack. I was laughing so hard I couldn't stop her. She drove right past me waving like a good neighbor should...with the drop light on the roof and 15 feet of cord trailing her.
Pretty "dim" thing to do.
OPPS!  LOL!!   I haven't done that yet. I wonder what happened when she got where she was going and found the light.  HEHEHE
I talked to her when she came home today. She made it 20 miles to work, and still didn't see it. A co-worker parked next to her, and came inside and asked about it.
She was still embarrassed when she got home.
I must have laughed too hard...Now her husband wants to borrow my droplight.
Should I let him borrow it?
Considering what they did to theirs, Id be skeptical.... :cheers:
He has two boats, and always has beer in his garage....I think that I will let him borrow it whenever he wants.
It's all about the beer.
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 815 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
