GMT900 Automatic Heater Control unit
I have a used automatic control unit. part # 25869946. Couple of the buttons are worn but other than that nothing is wrong with it. First 30.00 plus shipping takes it.
  • 1 year later...
I know it has been a while since this was posted, do you still have this unit available and is it still $30.00 plus shipping? Please let me know. Thanks!
One other question, you state that it is fully functional. How do you know that? Did you test it in a vehicle? What happened to the vehicle it came out of? I just want to make sure this one works. I've already been burned a couple of times on this item. Seller claimed it worked completely, but then it did not. I'm just being more cautious this time.
Is this a bolt in replacement for the knobs?
No, it would require major modifications to work.
Is there any way for me to contact Spryguy? According to his profile, he has not been on the forums since Nov 2013. I really need to get this part for my car. My buttons are non-functional.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 906 Guests (See full list)
