Remote Start - Won't
I have a 2008 Yukon XL SLT, 5.3L. My remote start doesn't work. I press the lock button on the fob, the locks lock and then I press the start button. The parking lights flash as they should, but nothing else happens. All fuses appear to be ok. When I try the remote start while standing next to the truck with the hood open and the fuse block cover off, I can hear a relay click when the doors lock and again when the parking lights flash. I don't hear anything else.
The truck starts and runs fine when I start it with the key. I don't know if it's related or not, but the power outlet at the back of the center console, under the rear HVAC/audio controls doesn't work, either. The outlet inside the console and the ones on the dash do work. I checked both accessory outlet fuses and they're good. I even switched the fuses around to be sure.
Has anyone else had this problem? Where else should I be looking?
Thanks.
I had this happen once to me on my last truck 2008 Avalanche then it just started working on its own. the other time I had a trouble code which would not allow it to start,
Well I know for sure it won't work with the hood open. Also wont work if the check engine light is on or I think if gas level is extremely low. Also, I think it can be disabled in the DIC controls so you may want to check that.
I've had a TPMS warning due to a bad wheel sensor for a while now. I was planning to take care of it with my next tire rotation. I just noticed that the check engine light is on now, too. It's probably something minor. It seems to run fine and fluid levels are fine. I have an appointment for an oil change and tire rotation next week. I'll have any codes read and fixed and it should start working again.
Sorry for posting under the wrong vehicle. I didn't notice where I was when I opened the forum page.
Thanks.
  • 4 months later...
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 288 Guests (See full list)
