Wheel spacers question
Have a 96 gmc sierra 4wd. stock wheels eventually gonna put 285 tires on. would like to run wheel spacers. to me its looks like the back wheels sit in further then the front. am i wrong thinking that i should run 2 inch spacers on the rear and 1 or 1.5 on the front? did a search and found alot of useful info but no real answer to this. Thanks
OEM wheels have same offset front and back. 265/75/16 tires came standard on the K1500 models if not mistaken. Going to 285 series tires on OEM wheels should work fine with no interference issues.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
