fuel pump not working, and my head is scratching.
spankrz
my truck is a 07 nnbs silverado 1500 extended cab 6.5' bed 4x4 5.3 engine vin "j", almost 170,000 miles.
a couple of weeks ago check engine light came on, "lost communication with fuel pump" or something along those lines. cleared the code, light was back on within a few minutes. truck still ran as it should.
this morning, got in the truck to get some work done and it would not start. fuel guage still worked. starter would enguage and engine would turn over as it should, but would continue to do so without starting. tried turning key on and off several times to build up pressure, no luck there either.
-fuel pump fuse is fine checked with multimeter
-fuel pump relay is fine via swapping with an identical relay.
---pulled off bed---
-installed new fuel pump from carquest, no change. wiring connections looked clean and not burned. fuel guage works as it should.
---called local dealer. they recomended fuel pump control module (located above spare tire)---
-installed new gm fuel pump control module. no change.
---with my hand on top of the fuel pump and someone turning the key to the "run" position, i can fell that it does nothing at all when it should prime.---
sorry for the long post, just wanted to provide any details that someone may ask. i really hope it is not a wiring problem, as i would hate to cut up the nice neat factory harness to check for faulty wiring unless i absolutely have to.
ANY help or input would be appreciated. feel free to ask any questions, i usually wind up looking over the stupid simple things...
i would look into the "lost communication with fuel pump"
error code you originally got with the dealer before pursuing any further with it.
It may be the cheapest way for a True Fix...
Scooby
Well if you have a 200 to 2007 old body style Chevy or GMC truck you may
get that annoying abs and sometimes the fuel pump that won’t work. This
is a common issue and usually just a bad ground on the driver-side
frame just under the drivers door by the body mount. Simple repair just
unbolt these grounds and sand the frame where they make contact clean
the terminal as well. I would use 80 grit sandpaper to do this when you
got them clean just bolt them back up make sure they are tight and can’t
be moved by hand. Hope this one helps you out you can do this without
spending a dime.
Quotted from A gm site.
Scooby
Scooby
^^^^^^^^^^^^^^^ +100 ,stop the shot guning of parts(i think you have at this point) ,,,,,,did ya have the FPCM programmed ?or did someone tell you its plug and play ?let me know ,i can look it up for you if ya want,,,
i believe ya looked past the computor controlled truck thing,,,good luck
mine is the new body, it is the truck in my signature picture. i was thinking about hitting it hard with the voltmeter tomorrow, seeing where i have power and where i do not, checking my grounds along the way, doing what you said to grounds that arent very strong. i was really hopeful that there was something i was missing that should have been obvious to check, or maybe an electronic part that i don't know about that i need to make sure and check. thanks for your imput, as said before, any response is appreciated. i have a lot i need to haul right now, just trying to get it done.
no, although my dealer reccomended that i install a new one, they failed to mention that the FPCM needs to be programmed. hopefully this is the "duh" response i am looking for. how do you program them?
dealer programs them
i hope ya have schematics because ya have to understand the systems before self diagnosing ,going by the seat of your pants will not work ,,,,i hope the programing works ,,,,,,
good luck ,,,,,,take it there for a programming first !!!
i may have to ask my dealer why the reccomended i buy a part, handed me the part new in the box, knowing exactly how i was going to use it, failed to mention that they needed to program it otherwise it was a $150 peice of plastic with a few useless circuts... maybe just a long day. any idea how much time they will charge to program it? half hour? hour?
i dont know ,cant be over an hour ,,,,
here is light reading,lol
Circuit/System
Description
Modules connected to the high speed GMLAN serial data circuits monitor for
serial data communications during normal vehicle operation. Operating
information and commands are exchanged among the modules when the ignition
switch is in any position other than OFF. The high speed GMLAN serial data
circuits must be operational for the vehicle to start due to body control module
(BCM) and engine control module (ECM)/powertrain control module (PCM)
communications. The theft deterrent module and ECM/PCM exchange information
using the BCM as the gateway module allowing communication between the high and
low speed serial data busses. The low speed GMLAN serial data circuit must also
be operational for vehicle starting.
Diagnostic Aids
  • Sometimes, while diagnosing a specific customer concern or after a repair,
    you may notice a history U-code present. However, there is no associated
    “current” or “active” status. Loss-of-communication U-codes such as these can
    set for a variety of reasons. Many times, they are transparent to the vehicle
    operator and technician, and/or have no associated symptoms. Eventually, they
    will erase themselves automatically after a number of fault-free ignition
    cycles. This condition would most likely be attributed to one of these
    scenarios:
    • A control module on the data communication circuit was disconnected while
      the communication circuit is awake.
    • Power to one or more modules was interrupted during diagnosis
    • A low battery condition was present, so some control modules stop
      communicating when battery voltage drops below a certain threshold.
    • Battery power was restored to the vehicle and control modules on the
      communication circuit did not all re-initialize at the same time.
    • If a loss-of-communication U-code appears in history for no apparent reason,
      it is most likely associated with one of the scenarios above. These are all
      temporary conditions and should never be interpreted as an intermittent fault,
      causing you to replace a part.
  • Do not replace a control module reporting a U-code. The U-code identifies
    which control module needs to be diagnosed for a communication issue.
  • Communication may be available between the BCM and the scan tool with the
    high speed GMLAN serial data system inoperative. This condition is due to the
    BCM using both the high and low speed GMLAN systems.
  • An open in the DLC ground circuit terminal 5 will allow the scan tool to
    operate but not communicate with the vehicle. When the scan tool attempts to
    communicate with the vehicle a message "no CANdi module detected" will be
    displayed.
  • The engine will not start when there is a total malfunction of the high
    speed GMLAN serial data bus.
  • Technicians may find various Local Area Network (LAN) communication
    Diagnostic Trouble Codes (DTC) and no low speed GMLAN communications with the
    scan tool.
    These conditions may be caused by the installation of an aftermarket
    navigation radio module (see bulletins). Some customers may comment of one or
    more of the following concerns:
    • Vehicle will not crank.
    • Vehicle cranks but will not start.
    • Vehicle stability enhancement system warning lights and messages.
    • PRNDL gear indicator position errors.
    • Tire Pressure Monitor (TPM) system warning lights.
good reading. i guess here is possibly the most important question... does my dealer have to program the module through the obd2 port, meaning i would have to cough up the money for a tow, or can i hand them the module? i am guessing it will have to be obd2 but i hope not.
  • 9 months later...
I did the same thing, local "largest GM dealer in maine" sold me the part and didnt say boo... now I got the old one out ( pissing water out of it ) and got the new one in but have to have it towed to drop 100 bones on a program... figures right?
Side note, my truck also has 170k is miles on it
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 822 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
