2007 1500 w/VortecMax package - Tranny noise
Hi,
I have a 2007 1500 (new style) with the Vortec-Max package. Truck has about 68k miles and I use it mostly to tow a race car trailer (about 8500-9000 lbs).
In the past month, the transmission has started making noises. Best described as a "squealing" noise, similar to the noise a brake pad makes when it is thin and the metal tab makes contact with the disc. It sometimes changes to a noise like a lawn edger makes when it hits the cement sidewalk. (Just trying to describe the noise best I can!)
Occurs under a load (towing a trailer) with light throttle and going about 15-20mph. Mostly happens in 3rd or 4th locked-up. Add gas and it goes away. It sounds like something inside is grinding itself up.
I have the GM Extended warranty and will try to use it. But....the computer has been re-flashed by Black Bear (about 4 years ago) and I wonder about the dealer reaction if their scanner shows the tune change.
So, questions are:
- Guesses about the noise?
- Others that have gone to dealers with a 'tuned' computer?
Thanks
walt
I dont know about the tranny but is black bear tune worth it? how much more power does it give to the truck? thanks hope u fix your truck.
Could be a case of the 4L60E's. You have either a 65 or 70 but same basic transmission
Sent from my Samsung Galaxy S4 using Tapatalk 4
Hi,
Update and (some) questions answered:
Black bear tune - it did make a difference although I didn't dyno or race it before and after to get 'real' numbers. All I can tell you is that towing my (old) open race car trailer over the same route, "after" was downshifting less and pulling hills better. Of course, the AFM had been defeated also. Black bear people said "we love to tune the 6.0 engines and usually have picked up 30 rear wheel hp".
Problem:
- u-joints not the problem. I can make the noises while standing still and 'stalling up' the convertor to about 1000-1200 rpm. Noise was a little different in forward than in reverse.
- 4L65e is what I have been told. Big difference is 5 planetary gears instead of 4 in the 4L60e. I've never been really pleased in the way it acted in daily driving as well as towing, especially with the new enclosed (heavier) trailer.
The problem has not been fixed, but solved for me. Sold the truck to CarMax in Ft Worth today. If you want to fix it, watch their auction sites (black 2007 new style 1500 with bed shell).
Bought a 2006 3/4 ton Duramax. So a whole new world to stumble around in!!
Later
walt
Your truck has a 4l70e. Rpo code is m70 in the glove box. They started using the 70e with the release of the 06 vortec max trucks wiyh the lq9. Drop the pan and take a look for rubble
he traded it ,,,,duh
Hi,
Problem:
Later
walt
you'll love the allison !!!! dirtymax isnt bad either lol
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
