Intermittent Starting Issue
I have a 2003 GMC Sierra that is having issues starting at times. The truck runs for weeks or days fine then when you turn the ignition key all lights come on but nothing. If I wait a couple of minutes it will start fine and I may not have the issue again for weeks or months. The truck has been a great one and has 200,065 miles on it with almost no repair needed other than a new alternator I replaced a couple of years back. I can hear the fuel pump prime but not even a hit when I turn the key to start it. I've been looking at forums and seeing it could be anything from the PassCode security to the BCM. My thoughts are starter, Ignition switch, and now thinking BCM from other posts I've read else where. I'm reading that there are a lot of people with the same issues but can't find posts telling how they resolved it. I've also read people spend hundreds of dollars on professional repairs only to have the issue come back in a few months.
Any help or suggestions would be great.
  • 2 months later...
Having this same issue with my 2010 Sierra Crew. Worked fine for 1 year then standed my wife - taken to shop and new battery installed under waranty. No issues for about 2 years then started happening again. New battery installed but problem is still occurring.
I have found out that rocking or jerking the truck while parked allows the problem to be temporarily fixed and allows the truck to start.
All electrical accessories still work but the truck ignition will not activate. Locked out from starting for some reason???
Any assistance? It has only occurred in cold (-20) weather so far.
Thanks
  • 4 months later...
Exact same issue with my 03 Silverado (300K miles),
Sometimes pulling out the key and re-inserting works, sometimes not...
I'll try the rocking trick when it happens next time.
My first suspect was the ignition switch. My fear is that something is "going out" and will eventually completely die all together, leaving me stuck like Chuck!
To the OP, did you ever track this down?
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
