Human Shield Mission
TxDoc
I wonder if they actually think that we give a horse's patooti. :cheers: Freaks!
Maybe we should all sign up for it and then when we get there just beat the he!! out of the people who are taking it seriously and then move out of the way for the military.  Or beat the crap out of them, then infiltrate the castle and take care of Sadam ourselves.
So whos up for it?  You think we could get a GMTC Sponsorship?   :cheers:
If they wanna stop a bombing run, then they need to put brand new GM trucks around the site and on the roof---no American pilot of sound mind would ba able to bomb such a site ;)
Can we send people like Barbara Streisand,Rosie O'donnel,etc,etc over there too?  ???  :cheers:
We could ONLY hope for something like this!!!   :wtf:
"We desperately need a bus and quite possibly busses. We need organizers, we need fundraisers, we need medical supplies and clothing (for the Iraqi people), we need all the help we can get!"
Send them some fords, viagra and g-strings. They do need all the help they can get, mentally.
Anyone have a spare bus lying around?     Idiots.
:flag:  :flag:  :flag:  :flag:  :flag:
:smash:  :smash:
I like Elwood's idea.  :flag:   Probably after they get there and start to organize, the Iraqi army will kill them all and try to blame it on the US and G.B. (Of course the French will immediately agree fully that is what happened! )
I have nothing wrong w/ our rights to protest, but this is about like going into the woods to hassle deer hunters - stupid!!  :smash:  :smash:
