Does anyone have pics of dashmats installed in a NNBS? I am tired of looking at the crack in the dash of my 2010 Silverado, and am going to order one. I'm leaning toward the Ultimat by dashmat as its supposed to be molded to the contours.
Every person to themselves but can I ask why you want this out of curiosity?
I guess im just tired of seeing the crack, and too cheap to drop $200 on replacing it just to have it crack again
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
