DTC 0342
I have a 02 Sierra 2500HD with an 8.1L. It's throwing 0342 code still after changing the cam position sensor and the connector to the ECM. All DTCs were erased after the replacement but keep coming back. Any technical help would be appreciated
Have you checked the crank sensor? On my 01 a faulty crank sensor was throwing a cam code as well as sporadic dieing and hard to start
DTC P0342
Circuit Description
The camshaft position (CMP) sensor works in conjunction with a 1X reluctor
wheel on the camshaft. The powertrain control module (PCM) provides a 12–volt
reference circuit to the CMP sensor as well as a low reference and a signal
circuit.
The CMP sensor determines whether a cylinder is on a firing stroke or on an
exhaust stroke. As the camshaft rotates, the reluctor wheel interrupts a
magnetic field produced by a magnet within the sensor. The sensors internal
circuitry detects this and produces a signal which the PCM reads. The PCM uses
this 1X signal in combination with the CKP sensor 24X signal in order to
determine CKP and stroke. This diagnostic for the CMP sensor checks for a loss
of CMP sensor signal.
Observe that as long as the PCM receives the CKP sensor 24X signal, the
engine will start. The PCM can determine top dead center (TDC) for all cylinders
by using the CKP sensor 24X signal alone. The CMP sensor 1X signal is used by
the PCM in order to determine if the cylinder at TDC is on the firing stroke or
on the exhaust stroke. The system attempts synchronization and looks for an
increase in engine speed indicating the engine started. If the PCM does not
detect an increase in engine speed, the PCM assumes the engine speed incorrectly
synchronized to the exhaust stroke and re-syncs to the opposite CAM position. A
slightly longer cranking time may be a symptom of this condition.
Conditions for Running the
DTC
The engine speed is less than 4,000 RPM.
Conditions for Setting the
DTC
The PCM detects the cam signal is stuck low when the signal should be high
for 1.5 seconds.
Action Taken When the DTC
Sets
  • The control module illuminates the malfunction indicator lamp (MIL) on the
    second consecutive ignition cycle that the diagnostic runs and fails.
  • The control module records the operating conditions at the time the
    diagnostic fails. The first time the diagnostic fails, the control module stores
    this information in the Failure Records. If the diagnostic reports a failure on
    the second consecutive ignition cycle, the control module records the operating
    conditions at the time of the failure. The control module writes the operating
    conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the
MIL/DTC
  • The control module turns OFF the malfunction indicator lamp (MIL) after
    3 consecutive ignition cycles that the diagnostic runs and does not fail.
  • A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
  • A history DTC clears after 40 consecutive warm-up cycles, if no failures are
    reported by this or any other emission related diagnostic.
  • Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
The following conditions may cause this DTC to set:
  • Camshaft reluctor wheel damage
  • The sensor coming in contact with the reluctor wheel
  • Foreign material passing between the sensor and the reluctor wheel
Using Freeze Frame/Failure Records data may aid in locating an intermittent
condition. If you cannot duplicate the DTC, the information included in the
Freeze Frame/Failure Records data can aid in determining how many miles since
the DTC set. The Fail Counter and Pass Counter can also aid determining how many
ignition cycles the diagnostic reported a pass or a fail. Operate the vehicle
within the same Freeze Frame conditions such as RPM, load, vehicle speed,
temperature, etc. that you observed. This will isolate when the DTC failed.
The CMP sensor output can be tested. The sensor must be supplied with a power
and a ground. The engine must be cranking to perform this test. You can measure
the duty cycle at the signal circuit of the sensor. The duty cycle should be
between 45–55 percent for a good sensor. An internally shorted CAM sensor can
pull the 12-volt reference circuit low causing DTC P0335 to set.
If the problem is intermittent, refer to Intermittent
Conditions
Test Description
The numbers below refer to the step numbers on the diagnostic table.
DTC P0342
Step
Action
Values
Yes
No
Schematic Reference: Engine Controls
Schematics
Did you perform the Diagnostic System Check–Engine Controls?
Go to Step 2
Go to Diagnostic
System Check - Engine Controls
2
  1. Install a scan tool.
  2. Start the engine.
  3. Monitor the CAM signal input high to low and low to high
    transition parameter using the scan tool.
Does the scan tool parameter increment?
Go to Step 3
Go to Step 4
3
  1. Observe the Freeze Frame/Failure Records data for this DTC.
  2. Turn OFF the ignition for 30 seconds.
  3. Start the engine.
  4. Operate the vehicle within the Conditions for Running the
    DTC as specified in the supporting text or as close to the Freeze Frame/Failure
    Records data that you observed.
Does the DTC reset?
Go to Step 4
Go to Diagnostic Aids
4
  1. Turn OFF the ignition.
  2. Disconnect the CMP sensor. Refer to Camshaft
    Position Sensor Replacement
  3. Turn ON the ignition, with the engine OFF.
  4. Measure the voltage on the CMP sensor 12-volt reference
    circuit using the DMM connected to battery ground.
Does the voltage measure near the specified value?
B+
Go to Step 5
Go to Step 7
5
Measure the voltage from the CMP sensor 12-volt reference circuit to the CMP
sensor low reference circuit using the DMM.
Does the voltage measure near the specified voltage?
B+
Go to Step 6
Go to Step 9
6
  1. Start the engine.
  2. Monitor the CAM signal input high to low and low to high
    transition using the scan tool.
  3. Momentarily and repeatedly probe the signal circuit with the
    test lamp connected to B+.
Does the CAM signal input high to low and low to high transition counters
increment when the test lamp contacts the signal circuit?
Go to Step 15
Go to Step 10
7
  2. Disconnect the PCM connector C2 located on the opposite side
    of the manufacturers logo. Refer to Powertrain
    Control Module Replacement
  3. Test the resistance of the CMP sensor 12-volt reference
Does the resistance measure within the specified range?
0–5 Ω
Go to Step 8
Go to Step 12
8
Inspect the CMP 12-volt reference circuit for the following:
  • A grounded circuit
  • A poor connection
Did you find and correct the condition?
Go to Step 19
Go to Step 16
9
  2. Disconnect the PCM connector C1, located on the same side as
    the manufacturer's logo. Refer to Powertrain
  3. Test the resistance of the CMP low reference circuit using
    the DMM.
0–5 Ω
Go to Step 16
Go to Step 13
10
  2. Disconnect the PCM connector C1 located on the same side as
    the manufactures logo. Refer to Powertrain
  3. Test the resistance of the CMP signal circuit using the DMM.
0–5 Ω
Go to Step 11
Go to Step 14
11
  1. Turn ON the ignition, with the engine OFF.
  2. Test the CMP signal circuit for the following:
    • A circuit shorted to a voltage
Go to Step 19
Go to Step 16
12
  1. Inspect the CMP sensor 12-volt reference circuit for an
    open.
  2. If you find an open circuit , repair the CMP sensor 12-volt
    reference circuit. Refer to Wiring
    Repairs
    in Wiring Systems.
Go to Step 19
Go to Step 16
13
Repair the CMP low reference circuit for an open. Refer to Wiring
Repairs
in Wiring Systems.
Did you complete the repair?
Go to Step 19
14
Repair the CMP signal circuit for an open. Refer to Wiring
Repairs
in Wiring Systems.
Go to Step 19
15
  1. Inspect for poor connections at the CMP harness connector.
    Refer to Testing for
    Intermittent Conditions and Poor Connections
    in Wiring Systems.
  2. If you find a poor connection, repair the connector as
    necessary. Refer to Connector
    Repairs
    in Wiring Systems.
Go to Step 19
Go to Step 17
16
  1. Inspect the PCM harness connector for poor connections.
    in Wiring Systems.
    Repairs
    in Wiring Systems.
Go to Step 19
Go to Step 18
17
Replace the CMP sensor. Refer to Camshaft
Did you complete the replacement?
Go to Step 19
18
Replace the PCM. Refer to Powertrain
Go to Step 19
19
  1. Use the scan tool in order to clear the DTCs.
    DTC as specified in the supporting text.
Does the DTC run and pass?
Go to Step 20
Go to Step 2
20
With a scan tool, review the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
But seeing as the cam sensor uses the crank sensor for reference if there is a problem with the crank sensor you will possibly show a cam sensor code
Garbage in = garbage out.....
And heavens knows these trucks had a problem with the crank sensors being a little long and coming into contact with the flywheel early on....
Coming from a diagnostic master tech not a parts chaser. I was simply stating don't rule out testing the crank sensor as it could give you a false cam sensor code
I have been able to come from below, reaching up above by the firewall and after moving the harness to the side been able to slide the old one out for testing. Usually ones that have made contact you can see the groove on them at the tip.
I've been lucky not to break any I just make sure to move the harness/hoses above it to allow it to come straight out the top... It is a long sucker for sure but if you keep from twisting it it should come out no problem
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
