2005 Silverado battery light on
minerwelder
I have a 2005 Silverado 1500 5.3L HO, Battery light stays on, I've replaced the alternator, and charge module, and left battery disconnected for a day. Is there anything else?
have the battery and charging system tested. Most parts houses can dp this for you. Also take a multimetet and draw test the battery. If you see a draw, start checking the draw at individual fuses to find the drain, but if the light is always on, my bet is the battery or charging system
Sent from my Samsung Galaxy S4 using Tapatalk Pro
Also check grounding points, battery terminals, cables, and the alternator wiring harness
Tested battery and alternator,also couldn't find any drawing on system was wondering if ecm might need reset at dealer,but they want $75.00 just to look.
Pcm shouldn't need a reset. Check all the wires abd cables. Last time mine came on, it was because I pit a 2 pin alternator from 05+ on my 2004 truck that takes a 3 pin harness
I'll check out the harness, I'm sure it was correct but i'll check it and all the grounds, be a week or so my multimeter went in for warranty .
Before you replaced the parts, what was the voltage at idle? And at 2500rpm? After changing the parts, what is the voltage at idle and at 2500 rpm?
What is this "charge module" you changed?
On an 2005 and other years it has a module that the ground lead goes through from the battery its just below the - battery terminal it regulates the charge. been a couple of months since I changed alternator and module so I don't remember voltages but it is arround 12 Volts at idle now and goes up to 14+ at 2500, just barely happened upon this site so I'm asking here since I've already asked other people!
Replace the alternator with another one. My alternator went out and i replaced it with a new one from NAPA and the battery light would stay on so i exchanged it for another new one and it solved my problem
Don't have a load tester, Used volt meter after charging it has 12.84 volts disconnected ground and left over night had 12.68 volts.
I'll have the alternator check when I go into town where I bought it.
Have them load test the battery as well
You can perform a half-assed load test by using the starter motor. The results you see will be along the lines of a dna test. it will not tell you what is wrong, but it can tell you what is not wrong. Connect a volt meter across the battery. Take the fuse out or unplug the fuel pump, and crank the engine over for 15 seconds. Battery voltage should not drop to below 10 volts. If it does not drop below 10 volts, it is pretty safe to think the battery is ok. If it does not stay above 10 volts, then either starter or battery is likely bad. Take it someone that can test it with an AVR tester.
Replaced alternator, parts place could not test this alternator, load tested battery good, Light still on anyone know where to get good schematic on 2005 silverado charging wiring with charge module?
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,276 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
