Snow
City_Slicker
I am not sure where it was bu the day before yesterday, I posted we have had no snow and I forgot what it was. Then that night we got like 4 inches!!! Coincidence? I dont think so! :(  :(  :D  :crazy:  :crazy:  :eek:
:uhoh:  :D
We got about 4" last night as well.  I sick of it and ready for some nice weather.  I have a ton of things I want to get done outside but I hate working out in that wind and cold! :D
This is the first year I havn't been able to go snowmobiling this late that I can remember. (NE IL) It's 9 degrees out half the f!@$# winter and no snow.  :D
hihosilver -  Come out east we have snow... I just got back from doing about 600 miles in 5 days of riding... Got about 2150 miles on for the year... Sucks not to have snow.... :D
We've been doing the 1/2" every 2-3 day thing all winter really.  Then the crews go nuts with the salt.  That's what bugs me more than anything.  I love snow, I don't mind cold, but when we get barely anything and they cover the roads, it gets old in a hurry.  Hopefully the light dusting we have will melt again and the salt will wash/wear away, then blue can get another wash.
We got more overnight and this morning with quite high winds.  Took out power a bit south of here, and made for a fun school crossing this am...gotta love gov't budget cuts.
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
