Funny Commercial
General Lee 01
How about the new Dodge Hemi comercial?
Guy in a drag racer pulls up next to the dodge and say's "That thing got a hemi?"  Well this has a hemi to.......
Funny comercial.......... :smash:
a drag racer against a truck....hmmm....it's like putting a ricer (pick your flavor) up against a jet....but the jet also has to have a parachute coming out the back to hold it up!
HA!!
What I think makes it funny is that Mark Martin playes a perfect driving instructor, I could just see him now teaching a High School Drivers Ed class, he fits the part perfect! :smash:
