Truck Is Pulling Both Directions Randomly
SSSilverado23
Stop driving it and get it checked out ASAP! Why do you keep driving it, it's not going to get any better!
  • 3 years later...
Did you ever figure out what the issue was with the truck? My 2012 Sierra just started doing the same thing this weekend. 7 weeks ago I put in 2" spacers to level the truck. In the process I had to replace both upper control arms. I took the tuck in for an alignment and they replaced the ball joints on the lower control arms. Now $800 later and maybe 300 miles my truck is jerking left during hard braking or right during acceleration. When I say jerk I mean puts me in the other lane or almost off the shoulder. The only other time jerk was when I hit the first set of rumble strips coming to a stop sign (before I began to brake)....almost like something jostled and caused the same jerk that put me well over the center line.
Checking to see if anyone has ideas or a known cause so I can get to the root of the problem right away rather than have a shop guess and come away only with hundreds of dollars spent with no solution. This is my weekend vehicle for the most part so it hasn't been used a lot since the alignment and surely hasn't been abused.
Created account just to respond to this.
my '15 Tahoe LT did the same thing, but also threw the Stabilitrac errors. Turned out to be a right rear speed sensor going out causing stabilitrac to react improperly. $20 part.
Out of curiosity, were there any wheel sensor specific codes, or just generic Stabilitrac?
Also wanted to say it's too bad so many original posters leave us hanging. Another missed opportunity to learn.
I only had the Service Stabilatrac and Brake warnings. Only item replaced was right rear speed sensor.
Sent from my SM-G935V using Tapatalk
I have no warning or codes that come up. It doesn't happen all the time but the Traction control and Stabilitrack will automatically go to OFF and I cant switch them back one. Then they are fine the next time I drive it. I have been driving it small amounts to diagnose it more. Rotating the tires didn't do anything for me.
    tararebecca
    tararebecca
  • Who's Online   4 Members, 0 Anonymous, 640 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
