1997 Chevy 1500 4.3L - Check Engine Error Codes
Hey there,
I just purchased a 1997 Chevy 1500, the 4.3L model.
Its got about 150k miles on it, with a "recently rebuilt transmission".
Everything works well for the most part..
It doesn't start on the first turn of the key - you've got to do it a few times to get it to start.
The idle is a little rough at times - almost acting like the engine is going to die, though it never does.
Also, it has a bit of a rough transition between first and second gear sometimes..
So, I'm thinking a tuneup / o2 sensor / fuel filter..?
The codes I'm getting are:
P0171
P0300
P1870
Not sure what they mean.. Any thoughts?
P0171 System too Lean (Bank 1)
P0300 Random/Multiple Cylinder Misfire Detected
P1870 Transmission component slipping
Check fuel filter and replace if necessary
Check fuel pressure and flow
I'd clean MAF and throttle body
Of course check plugs/wires
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 307 Guests (See full list)
