2003 Sierra Transmission Oil Pan-Shift Bracket??
I have a 2003 Sierra Z71 with the 16 bolt deep transmission pan. I started to change out my filter today and was wondering how to drop the pan around the shifting bracket??
channel lock pliers ,,,use the driveshaft and pull the bracket over while removing the pan ,,,,bend it back after job is done !!!
Some go with the bend method, I have always used the correct size Torx bit on a ratchet and removed the assembly. Not that hard and no worries about bending stuff.
I tried with a small 1/4" drive rachet with a T40 torx, and have NO clearance. I have barely enough room to get on the bolt but cant get leverage to turn bolt.
If you live in areas that use road salt, corrosion has conveniently made it impossible for you to unbolt it. Just bend it, it wont break. If you are bound and determined to remove it, remove the front driveshaft and spray pb blaster or your favorite skunk piss on there and try again.
Can someone post a picture of exactly what is being "bent"? I would be extremely leery of bending anything to do with the transmission. :nonod:
Its the black shift cable bracket on the drivers side.
I am not familiar with what is under my truck to know what that is. But next time I crawl under there, I will try to find that.
    bellssn690
    bellssn690
  • Who's Online   0 Members, 0 Anonymous, 815 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
