My Beloved '93 Chevy Pickup Needs a New Transmission...
Just joined this GM Truck forum today and hope someone can steer me in the right direction. My beloved '93 Chevy K1500 Z71 Silverado pickup named "George" needs a new automatic transmission! :nonod: "George" has 177,000 miles on him. I bought him in April 2003 and he's been very good to me. The transmission started acting up a few months ago and one night it kept slipping between 2nd and 3rd and the engine wanted to overrev. Thank goodness we got home ok! The fluid smelled a bit and is brown (I had the transmission fluid/filter replaced twice since I've owned him). Had two mechanics check the codes and no codes came up... One of the mechanics said it was internal and not to drive very far. I parked "George" at the end of Oct. 2013 for the time being.
Am torn between whether to get his transmission replaced (new rebuilt from Certified Transmission out of Omaha NE for $2600 installed and a 3-year warranty) or look for another GM pickup. George also needs the front drive shaft replaced ($400), A/C compressor and/or clutch replaced (freon only stays in system for about three months) ($?), headliner replaced and a "football-sized" rust spot repaired. He's generally in pretty good shape. The interior is fine except for the headliner. His 350 (w/ aftermarket dual exhaust :) ) only uses some oil if you do a lot of highway driving at 65+mph. Oh, and the tape deck doesn't work anymore and needs replaced.
Have been reseaching newer GM pickups and have read unsettling stories including:
  • the electrical 4WD switch changing from 2WD to 4WD by itself and possibly causing COSTLY drivetrain damage
  • the transfer case oil pump shakes loose from vibration and causes a pin hole leak in the case; then the transfer case fails and needs replacement
  • the instrument cluster assembly or parts of it fails (i.e. oil pressure, fuel gauge, electronic odometer/gear shift indicator etc.
  • window regulators and other body parts frequently need replaced
  • the continued "infamous" 1/2 ton transmission failure problem at high mileage
  • ABS brake problems especially w/ the rear brakes
  • brake lines along frame rail rust and the cab has to be removed to get to the lines to be replaced!
George has the gear shift lever to go from 2WD to 4WD. He's got rear drum brakes instead of 4-wheel disc ones. He doesn't have an airbag (which I don't care for) and other fancy stuff like newer pickups do.
I did look at a 2000 GMC Sierra SLE Z71 Pickup just today. It's only got 128,000 original miles w/ a 5.3L V8 (single exhaust) :( , CD player :) , airbag :fume: , electric 4WD switch :fume: , buckets seats w/ console :) , 3rd door :) , GMC bedliner :) , mudflaps :) , factory floor mats :) , good tires :) . The interior only needs shampooed and it would look new. :) Was told it belonged to a local 91 year old farmer who passed away within the last year. He was the original owner and drove it to the field and back. The price of it is $6,250. This is a very nice pickup and I'd love to get it if I'd decide to go w/ a newer pickup, but right now I have a hospital bill to pay. If I got a newer pickup, I would hope that I wouldn't have buyers remorse down the road. I know it's a gamble a person takes with ANY vehicle they purchase (whether new or used)...
With what research I've come up with, which way should I go: get "George" fixed up or buy another pickup? If I got another 1/2 ton, I would hope and pray that the transmission would not go on me like George's did or some other HUGE expense!
Thanks in advance for any advice or suggestions. I dearly love "George" and it would break my heart if I had to say goodbye to him. He's one of my "four-wheeled children..."
Maggie
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 775 Guests (See full list)
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
