OEM 2014 Double Cab Running Boards
I've got a set of factory Double Cab 6" running boards for sale. I took them off almost as soon as I got the truck home and don't plan on putting them back on. I'm in Michigan and not looking to ship these.
$350
Are you dead set on not shipping your assist steps?
Sent from my SM-N900V using Tapatalk
I wouldn't even know where to begin to ship these things. I doubt it would be worth the effort, so I'm holding to the no shipping policy.
Would you be willing to drive to St. joseph Michigan?
After thinking about it a few days, I could drive to St Joe. It would have to be a weekend and I think the next available one I have is April 26-27. Let me know what you think.
If they're still for sale where about in Michigan are you? I might be interested, I am in macomb county
Like I've said before, I wouldn't have the slightest clue on how to ship these and guarantee they wouldn't be damaged upon arrival.
  • 3 weeks later...
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
