High country fog light bezel
Anyone know the part number for the chrome fog light bezel? Looking to CM my chrome bumpers and put the chrome bezels in
Sent from my SM-N900V using Tapatalk
  • 5 weeks later...
I painted the bezels on my 14 all terrain. Took them off with the bumper still on. If you have big hands your going to have to take the bumper off and that means the grill and top bumper pad will have to be removed. It took me about 25 min to take each side off and about 35 min each to put back on. Using swivel and small wrench. There's 4 number 7mm screws in each corner of the bezel. Very frustrating.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 630 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
