In theory, as long as the overall diameter of the tire is the same, then the overall drive ratio would be the same. IE, and these are just estimated numbers, from 265/65/18 to a 265/45/22 may yeild a similar overall diameter and thus same gearing/tow capacity. That said- two things working against you- first, make sure the lower profile tires are designed to carry enough weight, and two, you probably will be increasing the overall diameter because you wont use low profile 45 series tires on your truck, thus shortening your effective gear ratio- your 3.42 will feel like 3.08, and will be restricted to something like the tow capactiy associated with that. Post what size tires you want and we can give more precise results.
  • 4 weeks later...
Just use the same saze as the OEM 22" trucks come with. They are basically the same size. 285/45/22 Should get you within less than 3/4 of an inch of the same overall diameter
The 285/45R22 is the best bet. It will fit, require no tuning, and still be within all specs in the manual
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
