Better gas mileage?
I agree here. Towing or empty there is a sweet spot. That sweet spot varies truck to truck and owner to owner. For example for my on the highway while empty my sweet spot is 78 MPH. Engine spinning 2k and pulling about 17.5 MPG by the DIC. Spend some time experimenting.
Yeah when I'm empty in hwy I get to about 77 and it's showing 18-20 mpg
  • Replies 39
Like I said every truck is different. Driving style will play into it hugely. I drive 130 miles to class and have to make it in about 2 hours. Cruise control set to the speed limit will yeild some damn good numbers
Not to flame or insult, but if you're worrying about MPGs and towing at 75 mph, you're gonna have a bad time.
Lock it in between 60-65 and let it roll in the right hand lane. Don't be those jackasses you see hauling a full trailer at 75mph weaving in and out of traffic and riding the left hand lane.
It's not a race, especially when you're pulling a load.
Speed limit is 75 mph, I stay with traffic why go 10 mph under the speed limit at some areas it's even 80.
I can't even comprehend how you do not comprehend that speed and mpg are directly related to each other. Sorry, there is nothing out there to improve mpgs hauling trailers at 75mph and there's no one researching it.
Side note, "keeping up with traffic" is a very unsafe practice while hauling a trailer. But you know it all.
Apparently you know it all yourself to. I simply asked is there anything to do to improve the gas mileage as far as add ons.
Yeah but everyone keeps giving you advice about it, since no magical bolt on exists, but you keep denying the fact that it's your driving habits that are 100% of the problem.
I don't know it all, but I do know hauling a fairly loaded trailer at 75mph "with traffic" is unsafe with any truck. Period.
Okay just read threw my topic, when did I deny that going 75 was not the factor???
I simply asked if anything would help as far as a bolt, if you read threw it I say I'm happy with the truck as we'll,
I'm guessing you don't live in West TX the oil field traffic is all over the hwy stay with traffic or get plowed over.
If 8-10 is what it's going to get in fine with it due to the fact I'm hauling the trailer usually every other weekend. I spend more time not hooked to a trailer.
Although this weekend I went to the lake a 2 hour drive. Hooked to the Seadoo trailer going 75 there and back averaged 19.4 mpg
Yeah we'll that's the speed limit haha gota stay with the trafic, lol. So basically that's what I'm going to be getting nothing will help
The limit is 75. doesnt mean you cant go 65-70. Just slow down....should help with MPG. no business going 75 with a trailer anyways.
You should probably take a look at your trailer tires. Most likely they are ST tires and only speed rated to 65 Mph.
I'll take a look at em we actually just put all 4 new tires on it to and keep the bearing buddies filled with plenty of grease. But I will double check the tires
Just tryin to help pal. Not saying you need to slow down. Just that if you want better fuel economy, it won't hurt to slow down.
I hear ya there I did slow it down my last trip to the dunes to try and see what it will do. I can't say it was me slowing down or the fact I only took one rzr but I got about 11-12mpg I stayed in 70mph the entire time, one thing that I bet gets me are the rzrs roof.
Is a 1/2 ton 5.3 capable of pulling say a 20-24 foot enclosed trailer?
Try covering the rzr's might help reduce drag.
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 479 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
