Coil Over Conversion Prep Help Needed
I've developed a deep hatred for torsion bars on these trucks. This started with my first 4X4 in '96, a Z71 K1500. My Tahoe leveled, rides about like my son's unsprung gokart. On the other hand, I have a leveled '10 F150 with Coilover/Struts that rides like a dream. I love the Tahoe, everything about it aside from the ride. So this got me thinking of a conversion....
Second point, my front end is lifted between 2-3", and I have 1" blocks in the rear. I like this height, any higher and I won't fit in my garage, but I'm not happy with the CV and Steering angles. There are no complete aftermarket lift kit options to remain at this height without modification to their design. If I decrank a 4" kit, the spring rate is too soft to support my ranch hand replacement's weight in the front.
So here I am, stuck with designing a solution. The plan to date is to order a set of Coilover supports from Atomic. This gives me endless options for shock and spring rate/weight. To correct the upper ball joint angles, I've ordered a set of Cognito UCA's. Happy with the plan so far, but I still have a couple issues to address.
For the cv angles, I'll need to drop the front axle. Has anyone seen an axle bracket kit for around 2" of drop? If I can't locate, I will build one.
Steering angles are still a little far stretched, so I'll need to locate a dropped centre link, or some other solution if any suspension guru's have any ideas.
I guess what I'm looking for is a few (constructive) opinions about the system as I've listed, and any help that can be offered to locate the last two points mentioned. Thanks in advance for any suggestions!
I don't know if there is any way to only drop 2". I believe the redesigned RC 3.5" kit for the GMT900's had a small drop like that, not sure how much though. I'd look around and see what guys have done for their conversions, I know there are a few on different sites. The primary advantage of torsion bars is they oppose each other and take stress off the front of the frame. I know there was a guy with a heavily modded pickup who had converted, I'd want to know how his has held up (gmfs I think).
    Camyon
    Camyon
  • Who's Online   4 Members, 1 Anonymous, 1,214 Guests (See full list)
