Sunroof wont close over 50mph
Is my truck the only one that does this?
I have never owned or been in a car that you cannot close the sunroof over a certain mph.
Over 50 or so, the system is too weak to close once the glass gets to the deflector.
I had the problem once but never a problem again -
Sent from my iPad using Tapatalk HD
Noticed this as well. Seems as though the 'obstruction' sensor is sensitive when it hits the wind screen. most of the time It can be overridden by pressing the close button manually.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
