Double Cab + 19x20 Garage
Moving south into a place with a 19x20 garage, I have a '14 double cab. Thinking it may not fit, but it is a 2 car single door garage so would coming in on and angle give me some play room?
If anyone here has any experience with this please let it fly!
I think if you go in on an angle, you might end up being "longer" than if you pulled in straight. If your double cab has the standard box, you come out to 19', and 2". If your bed is the long one, your going to be too long. 20' 7".
Good luck.
20' deep? Give you about 5 inches front and 5 inches rear room, so depth shouldn't be an issue but, if you are putting two cars in there...not sure.
Found out some more facts, the garage is 393 SQ FT...the outside bay is 20 feet long and then the bay hugging the interior of the house is 19 feet...looks like the interior wall of the house comes in for that side of the garage which cuts the length.
so as long as they didn't stuff the air handler AND the water heater in the longer bay I should be able to get the truck in there...truck is 19' 2"
it's a florida home so no basement...water heater and air handler would be in garage...home built in 2004.
Typically the size of the garage is measured by the outside footprint. So you need to take out the thickness of the walls,
My DC measured out at around 19.25 ft. Hard to see, but around 231".
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 399 Guests (See full list)
