What is the biggest tire option I have?
Ja93
I installed the nitto G2 285/55/20 and 1" leveling kit with stock wheels on 15' Denali and love the ride, looks, and no noticeable change in gas mileage, mag ride, or going into V4 mode. A friend put on 34.5x12.5 with 2.5 kit and doesn't look as good with stock wheels and rides terrible. He is going to sell his 2.5 and go 1.5 and the 285/55/20 after driving my truck. It looks like what GMC should have done and drives the way it should. I can send pics if you want to see difference. Just FYI. Am glad I didn't spend a bunch just to want something different so figured I would share.
  • Replies 32
Can you please send pics of both trucks?
  • 3 months later...
Truck looks great. What level kit do you have? Do you like the ride quality any issues with vibration. Thanks!
They definitely fit with just a level, mine are Toyo Open Country M/T, 275/65/20 = Toyo specs 34.5x11. They are in fact 34" tall but are 11" wide not the usual 12.5. Hope that helps.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
