New Ford Truck Rear Window Technology
RyanbabZ71
New Ford Truck Sports New Rear Window Technology.
The Detroit Free Press (8/14, Priddle) reports on the new high-tech window in the 2015 Ford F-150. The window is a single piece of glass made by Magna International that provides visibility, seals well, reduces cabin noise, and has the ability to defrost the rear glass even when the window isn’t open. The company noted that the size of the Ford program made the new technology a feasibility, and the company has patented several components of the technology.
And like always Ford will add another $3k to the already ridiculous price of their trucks for this unneeded overly complicated piece of technology.
not sure how i feel about this. I saw the pictures and it looks a bit strange. Is it because it is different than traditional? probably. I want a slider for my next truck, but one thing i think toyota actually got right is their rear window that rolls down. Not sure if it has defrost, but if not if GM could do defrost and a roll down rear window, that would be ideal i think.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
