1998 Chevy 3/4 Ton 4x4 Hesitation
Hello all from Texas. I have a 1998 Chevrolet 3/4 ton 4x4 extended cab with the 5.7 Vortec and Automatic tranny. I notice that my truck has been hesitating a little.
It seems almost like a miss. It only does it if i am stopped in drive with my foot on the brake. It does not do it if i am stopped and in neutral. And if i give it gas while other foot is on brake (power brake) the truck acts like it has no power and hesitates bad. it will not even power brake on gravel hardly. Yet, if i get going over 20 or so, it accelerates great. has alot of power going down the road. Plugs and wires are good. Has a brand new fuel pump and fuel filter. Plugs and wires fairly new. Does anyone hav ea clue what this might be. I have been told it could be the Mass Air Flow Sensor or something(MAF). Thanks for any help.
Not sure. Could they cause this kind of miss and hesitation? Wouldn't bad cats make it miss and hesitate at high speeds also. It is weird because if the truck is sitting in park and idleing, it doesnt do it. If i have it in drive and sitting there idleing with foot on brake, it does it.
Not necessarily, higher RPM your pushing more against the same restriction.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 909 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
