2014 Silverado will not start
afchief
Their trucks also will have issues,They are all built the same!Just learned a good lesson myself with this chevy!
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
