service 4 wheel drive
fighting the dreaded "service 4 wheel drive" problem on a 2004 avalanche. things I have done: verify fuses, verify power and ground to tccm, clean grounds on chassis under driver door. ohm test on selector switch. the ohms check out on all but the auto button seems off because has 006 ohms. cant find specs on that.
its been an intermittent problem. when the switch lights up the 4wd will engage normally so I suspect wiring problem.
for over a year the service 4 wheel drive message would come on occasionally but the selector switch would continue to work. by shutting vehicle of and restarting the message would go away. now the message comes on everytime and stays on.
Have ya the ability to see a garage to get the TCCM Scanned for a code to a least point ya in the right direction,
While it's there , they may as well diagnose it for ya ,,, make sense ?
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
