Help with 2014 Silverado 1500 (CC) Audio Build
So I recently swapped over from a 2009 335i with Logic 7 to a new 2014 Silverado 1500 crew cab. Its a very drastic change coming from a car with 11 speakers to 6 so time to upgrade.
I have been trying to find as much info as I possibly can but I am coming up short in a lot of areas. Everyone who starts an audio build seems to never finish it with our trucks.
Truck has a total of 6 speakers; 2 on the dash, 2 on the front doors, and 2 on the rear doors
Speaker Sizing:
Dash: 2.752" speaker diameter
Mounting Depth:?
Front Door: 6x9" Speaker diameter
Mounting Depth:?
Rear Door: 6.75" Speaker diameter
Mounting Depth: ?
My plan is to use to the following:
A) Front Door and Dash: Image Dynamics CTX65cs
Link: http://www.woofersetc.com/p-6201-ctx65cs-image-dynamics-65-component-speaker- system.aspx
B) Rear Door: Image Dynamics CTX65
Link: http://www.woofersetc.com/p-5557-ctx65-image-dynamics-675-2-way-speakers-w-silk-tweeters.aspx
C) Underseat Subs: (2) Image Dynamics ID10 V3 D2 and a Sundown SAZ-1200D
Link for subs: http://www.woofersetc.com/p-4992-id10-v3-d2-image-dynamics-10-dual-2-ohm-v3-subwoofer.aspx
Link for amp: http://www.sundownaudio.com/index.php/products/discontinued/item/saz-1200d.html
D) Sub Enclosure: SubThump Dual 10 Downfire
Link for enclosure: http://subthump.com/product_info.php?cPath=1_72&products_id=456
These brackets will be needed for the front doors since there will be size adjustment
- http://www.crutchfield.com/p_120823005/Metra-82-3005-Speaker-Mounting-Brackets.html?tp=2824
The only thing I really need is for someone to provide a mounting depth to make sure they fit. Instead of splicing the harness, I will cut the plug off the old speaker and solder the new speaker so that it can be plug and play and Chevy cannot get on me about a cut harness . As far as the dash goes, I will probably need a shop to get that done for me and still need to decide on amp to power the speakers. Other than that, input is appreciated
My 14 has 6.3/4 speakers in the rear doors, not 6x9s, fronts are 6x9's. Mine is a non bose system so maybe there is a difference. You will need to think about how you how you are going to get a signal to feed the amps. On my 13, i used a plug and play module. They do not have one yet for the 2014/15.
I did the kicker factory upgrade and it's pretty good but i am leanig toward a customer setup so let us know how your build goes...
ok so the rear are 6.75:". Crutchfield told me different :throwup:
I did it on mine, but I have the Bose system with the center mounted sub. Do you have the Bose system?
Nope, Non-Bose system here. Really hoping this will go as smooth as I am hoping.
Would anyone happen to know out mounting depth in the doors?
I am not sure the depth but most speakers will fit in place just fine. I installed jl audio c2 6 3/4 in my rear doors, used the mounting brackets i got from crutchfield that were in my 2013. The connectors are different on the 14 but the brackets were exactly the same. I was gonna put my c2 components in the front doors until i found out they were 6x9, have to get a different bracket. The rears are defiinitly a 6.5 to 6 3/4 speaker.
I have 6.5 inch Focal components and 6.75 Focal coaxials in the back doors. 12 inch Infinity sub (left over) under the back seat. Everything fit fine and sounds really good.
mannnnnnnnnnn that sub box looks nice ... i am about to to purchase the new JL audio duel flat 10 sub stealth box .... i have the 900/5 jl amp and as far as the doors and dash i have the JL ZR 650 component set . My nali has everything except rear entertainment so i have Advent DD7012 head rest monitors.
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 870 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
