Alignment and Speed Sensors???
sethhenry
Could one wheel speed sensor being disconnected during an alignment cause it to pull to one side? 97 GMC yukon. When I got it back it was pulling harder to the right then when I took it in. ABS light was on and I found drivers side speed sensor disconnected, but doesnt look like they even touched the other one. Just trying to get some info myself before I go talk to them tomorrow. Thank you
The alignment needs to be re done. Tell them which way it is pulling and that they need to do it again. Not sure why the wheel speed sensor was unplugged, ABS has nothing to do with the alignment.
Take it back and tell them to check all the front end suspension parts for wear first and if nothing is wrong align it again.
