need help with hid
just a quick question for anybody ordering hids from ddmtuning.com what did yall order with your kit any capacitors or harnesses if so which ones please point me in the right direction also im new to this site and just got my new sierra
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
