Changing Licence Plate Bulbs?
Hi Guys,
This is my first post. I have been lurking around this forum for the past few weeks. I finally pulled the trigger on a 2014 Sierra 1500 SLT 5.3 and I cant be happier ( previous truck was a 2007 Tundra)
My first mod was chaining the headlight bulbs to Sylvania silverstar ultras (very disappointed... stock bulbs seemed brighter)
any way..
I was wondering if someone can tell me how to change the licence plate bulbs. I tried putting my hand under the rear bumper, but couldn't seem to twist or turn anything.
Thank you in advance
Thank you, I changed them out today. You were right, I just had to put a bit more force into it.
Are you going to replace the bulbs with "better" ones only to be di$$apointed again?
I swapped them with LED bulbs to match the interior and flood lights.
lol... Yes, im only 81% satisfied. I will have to buy brighter LED's
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
