HD gooseneck
I dont know if it would void your warranty, I wouldnt think so, unless the gooseneck caused something to break. I had mine gooseneck welded in my truck (94) and I didnt do anything to the computer, I would probably unhook your posotive and neg. to your battery.
Why would you weld the GN Hitch?
Welding creates stress points on the frame and there is a heat affected zone around the weld.
I've got the bolt-in B&W turn-over and have been well pleased with it.  It's a good alternate to welding.
REMEMBER--WHEN AND IF WELDING ON ANY AUTOMOBILE--ALWAYS REMOVE THE POSITIVE CABLE----THIS WILL HELP FROM ARCING OUT THE ELECTRONICS ON IT-----this is from someone who has been a welder for 25 yrs--it is my professional opinion-welding on the frame will weaken it to a certain extent  where as bolting is the reasonable choice on frames and so forth    :thumb:  :thumb:
Well I read an article the other day about Chevy HD frames. It pretty much said since the are Hydro Formed, or somethin like that, that you arent supposed to weld or drill any holes in them. So that would leave you with the option to put a B&W turnover ball, gooseneck, they are made to bolt up to 4 existing holes in the frame. My dad has one is his 02 2500HD and it is a really nice gooseneck, they are a little pricey though. Lookin at dads recently it is starting to get some surface rust already after only bein in about 18 monthes or so. Might be a good idea to give them a better coat of paint or something.
Man you guys worry to much about stuff.  Weld the hitch to the to the frame undercoat it and be done.  No biggy.  Note: Vertical up, none of that sissy pulling your weld down.  If you can't weld now ain't a time to learn.  Oh I didn't but you might want to pull your negative battery cable of the battery..
Rodger.. I painted my B&W turnover ball.  Threw the factory bolts that came with it in the trash.  Installed the Hitch with Caterpillar heavy equipment bolts.  Then welded the hitch to the frames just because being a welder "In welds I trust"
Well, I just got finished welding the hitch in.  It's getting late so I'll drill the hole in my bed tomorrow.
Who dey!!!
You the man...
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
