2014 Silverado help on custom wheels
black2014silverado
OK I am a little confused. I am looking at upgrading my factory wheels and going with a 20. I have done the rough country 2.5 kit and currently running nitto 33s on the factory 18s. I am buying a 0 offset wheel but I want to know the biggest tire I can go without rubbing? I think the 285 65 20 but I can't find them on a truck so I am thinking my theory is off some.
  • 3 weeks later...
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 283 Guests (See full list)
