MyLink screen?
Has anyone tried a privacy protector to dim the screen? how did it work? found one today but said on box u cannot see it from a angle, which in the driver seat ur at a angle, I still cannot believe GM does not have the MyLink and gauges on a different dimmer
thanks
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
