2003 8.1 2500hd fuel level issues
So this truck hasnt missed a beat...62K miles.
Fuel pump quit. Dealer installed new and replaced the dash cluster that was acting crazy (that was a recall back in 2007-2008.
Gauges are all good and same readings as my digitals except fuel and
Got truck back 1/4 tank.
Added 8 gallons. Shows 1/4 tank. Right back to dealer he says "fill it up and it has to relearn bla bla.
Ok it reads full and is going down with use as usual.
Before I go further....let me say Ive never taken a vehicle to a dealer for service. EVER.
I do all my own because frankly they do piss poor work and do more damage than good.
(Dents, grease everywhere from dirty hands.....they dont give a Sh!t.
Anyway being winter and no garage to jack up bed or drop tank and being I have warranty I figured what the hell.
Mind you my fuel light came on before at 15 miles range and Fuel low DIC as well.
Exactly would be 2 gallons in tank. 24 to fill.
Yesterday......dies at light. No fire. No gas light on and 17 miles on DIC and about 1/8+ tank left on gauge.
i was ready for this..... Im not a fan of dealer service.
So I had my 2 gallon can of gas ready.
Dumped it in gauge same spot. Cycled key once and fired right up.
Today showing 1 line of fuel 16 miles left. NO warning light.
Tap tank from bottom. GAUGE drops to Red, DIC shows 11 miles. No warning light.
Cant be but a gallon in there.
What did they screw up or not fix right? Didnt calibrate it?
Im not buying it has to relearn anything BS.
1. Either its a junk module or sending unit,
2. STICKY float.
Any ideas? Or do they need to calibrate that with the pump the same way they programmed the new gauge cluster with the miles and hours?
Thanks!!!!
They don't program a fuel pump ,
Floats don't stick ,
Tech has to be a complete moron to mess up a fuel pump install,
Idk what to tell ya except buy a scanner
Thats what I was thinking except the gauge cluster was replaced at the same time and they do have to program the miles and hours into it.
Its Almost like the pump and float readings arent kicking the DIC to read right or trigger"low range" and the fuel light. Or the sending unit is bad.
Are they seperate? It worked fine before.
Right now its down at the bottom of red with Range 10 miles.
It never showed that prior. 15 was lowest and light and DIC came on.
Float is sticking. Each line denotes about 1.625 gallons of gas.
Put in 2 gallons even. Gauge didnt budge.
Tapped tank gauge jumped up and so did appropriate range on DIC.
Is it common for dealers to fix one thing and break 5 more?
Do they not do this on leased rigs knowing in 3 years they will have someone walk in hand them the keys and say take this POS?
What about luxury vehicles. Maseratis and Porsches? Or even high dollar 4x4 crew cab trucks?
Do they go in for an oil change and come out Mazdas and Pintos?
I was really REALLY hoping they could fix a simple thing right the first time.
Is there anything to this " it needs to relearn its levels etc" BS like the computer learns driving habits?
Bs to learning
All dealers go out of business because of shitty techs messin up customers veh's just like your experience
You got it right .....it's true ,
Speaking of Alberta....a buddy up there works in the oil fields.
New Dodge Cummins. Takes it in for free oil and filter change.
While there they bled brakes and topped off.
2K later he checks oil. This is all dirt roads and dust and mud.
Pops hood, no oil cap....its sitting in a tiny area covered with dirt.
NO brake reservoir cap either. Gone.
Hes suing dealer for a new truck.
He said " I don't know why I didnt check their work this time"
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
