April 17th
95whtZR2
Alright, it looks like it moves to May 23rd, my friends and I are gonna leave Central Texas to go to Shiloh, this is pretty sure the date, but if anything changes I will be sure and post, if you want to go let me know so I can get some contact info to inform you when we get there ect. my email is [email protected] and put shilohridge in the subject so I don't erase it on accident, or just PM me... I will keep in touch, and probably post this in the General Discussion the week before we leave just in case people don't look at this board(duh)...
Tom
    zibzer2
    zibzer2
  • Who's Online   6 Members, 0 Anonymous, 803 Guests (See full list)
