Battery Drain on 1999 Silverado
Newby, just signed in to see if I can get some help. I have a 1999 Silverado 2500, V8 6L. I rarely drive it. I replaced the battery, but it still drains down in about 3 or 4 weeks so that it will not start. For awhile, I just removed the negative battery connection and it was always ready to start when I re-hooked it. Then, in order to get a cheaper State Farm Insurance rate, they gave me a device to insert in the diagnostic receptacle to trace my mileage. So, I had to leave the battery cable hooked up.
My question: How can I measure the battery drain to locate what is causing the loss of charge? It was doing this before I added the monitor device, so it must be something else. I am not an EE, but I should be able to trace it with a little bit of help?? I have digital and analog voltmeters.
I know you want to do this yourself but the best fix is to have a shop do a parasitic drain test
This isn't a hard test to do guys. No need to run straight to a shop.
Hook up an ammeter in series with the positive battery cable (cable --> ammeter --> battery terminal). The meter will become part of the circuit.
Post back with your draw rating. You'll want to use the milliamps scale. Pull fuses one by one and monitor the draw rating until you observe a substantial drop.
When you see the drop, you've found the source of your draw.
Make sure when you do your interior fuses (you may have 2 or 3 fuse boxes) you make sure you keep your door sensor pushed in with a clamp so the trucks not drawing power to keep anything on in the vehicle
These trucks don't have door jamb switches like the older trucks. The switch is built into the door latch itself. To make the pickup think the door is shut, you will need to manually close the door latch while the door is open.
TIME OUT!! I THOUGHT THE BATTERY WAS NEWER THAN THIS! I noticed the tag 4/10, so it is almost 5 year old. I put the load test on it and it said "WEAK", of course. All tests suspended until I get a new battery, and then I will try again. I will mark this post as SOLVED. If I have further problems, I will repost. Thanks for all of the suggestions. Joe
My same thought - a 5 year old battery may struggle to stay charged in winter for 3-4 weeks ... I'll bet you'll be fine with a new battery
If you don't want to buy a new battery -
put a battery tender maintainer on the old one evey time you park it at home you'd be fine (though not convenient)
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
