Well guys
Jpshostr
I keep hearing about a eating utensil that is really nice, they call it a super bowl.  I'm gonna have to go check it out pretty soon.
Go Rams, die Patriots.  Three cheers for the commercials!
I've already seen one commercial that made me think of you immediately Jp.  It was the Budweiser one where the two guys were sitting in a bar and the one talking about not being good with asking women out, and ended up getting kicked.  LMAO!
So far the Bud comercials have been the best.  The one with the guys in the bar, and the one with teh woman looking for a card for her boyfriend and then him picking out hers have been my favorites so far.  But really I've liked all the Bud comercials.
HALFTIME NOW NBC.
Playmates Fear Factor.  ot that I'm gonna watch, but I thought you guys might be interested.  ;)  :)
Does NBC honestly think I'm gonna switch back over to them after the Super Bowl is over to watch four playmates swim in ice cold water while wearing bikinis?   ;)    :)
Only if Bob Villa isnt on HGTV redoing a basement somewhere.....
The VISA official card of NFL, Olympics, Triple Crown, and NASCAR was pretty good too.
And The Rams who suck azz just tied it p with 1: 30 left in the game and the Pats have no timeouts.  :)
I'll direct my reply for this to my new topic in sports.   But just so everybody knows.  I don't care that htey won, I just wanted to see overtime.
Ok, I don't know what the #### happened to the Rams.  I guess they were too cocky going in.  They had one heck of a comeback, but the way that kicker walked on the field with 7 seconds left, I knew they were doomed.  Gotta give credit to the Patriots for believing in themselves, I was hoping to see Bledsoe play though.
The commercials this year sucked!  Only good ones were the minifridge, falcon, and the bar one.  All the others were way too stupid or I just didn't get.  Halftime show was awesome, yes I was watching NBC. :)   Everyline those playmates said could be taken in a sexual way, man I laughed so hard.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
