I agree, a used one in that range is more likely for a midsized truck. That would work if I raised it to clear the cab.
Keep in mind I'm only interested in pop top campers. New four wheel campers or all Terrain campers are lightweight if I stick with the shell plus one or two options only. The obstacle there is, do I want to spend 10k.
My current ARE contractor cap is working for overnight stuff. It's about 50" inside. I'm toying with the idea of fabricating a small pop top for 2/3rds of it's roof. We'll see.
Edited by 12413
I have the same question. Only problem is I purchased the camper before I understood the potential issue. I bought a 2012 Palamino Bronco. Weighs about 1600 lbs.  Found out there is a plate in the glove box which indicates the slide in camper weight limit. This is about 650 lbs for my truck. Friend just bought a Chevy Silverado and his plate says "no slide in camper". I believe my GVWR and GCWR are thresholda are sufficient that I should be able to beef up the tires and the springs and be ok. Problem is the decal on the pillar does not give GVWR only a weight not to exceed based in the standard load tires.
I'm very frustrated trying to ascertain the real answer.
Any suggestions?
I don't see it happening with a 1500 as others said find your slide in camper weight rating, payload is not a correct gauge of the camper capability... Unless you're really limited on space I would just get a small camper to tow behind your truck...
  • 2 years later...
    KJEK
    KJEK
  • Who's Online   2 Members, 0 Anonymous, 454 Guests (See full list)
